gt40 intake install gone wrong
Pull the #1 plug...put your finger over the plug hole....rotate the engine until you feel the air from the compression stroke completely release thru the hole . .. check to see if the timing pointer is at -0-, pull the dizzy cap and see if the rotor is on the #1 plug wire. that will answer your question if you dropped the dizzy in right or not.
It is a little late, but heree is the installation tech note. Check out the vacuum line information.
Explorer intake swap.
I got mine off a 96 Mountaineer with the 19# injectors and 65 MM throttle body for $250.
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
index.php
index.php
Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater I have. You don't need heat very often here in Central Florida...
Also see http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together.  no leaks, and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together. Take the other advice you got here and run with it.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
index.php
index.php
Cap or plug the remaining lines since they aren't needed.
Here's some tips...
Consumable items:
I would double check the timing. I have heard that you can goof up and set the timing on the exhaust stroke and it will fire. just something to look for.
It is probably dealing with the distributor like I said previously and other people said. When putting in the distributor it is possible for it to be stabbed in there wrong. I did that my first time around and then had to go back in a fix it.
My moneys on your a tooth or so out of time. Bottom of Dist there is a gear that mates the cam to throw that spark around that cap just at the right time to make the boom in your cylinders.
Bring car to top dead center (#1 cylinder)on the compression stroke turn the rotor on the top of distributor to where the rotor is facing where the #1 spark plug would be on the cap if the cap was buttond down. What kind of MAF you using? They are calibrated for 19lb,24lb,30lb injectors ect....
is there an easy way to bring it the 1 cylinder to tdc without pulling the cover? i tried bumping it arround with no success.
i ripped the whole thing down again re torqued everything i still have a miss. if i mess with the distributor i can even out the idle for a sec. or 2 but if i rev the engine it sounds like its got a miss. im lost if i cant fix it soon its going on craigslist
assuming your balancer hasnt slipped, the best way to find TDC on the compression without pulling things apart is to take number 1s plug out, sick your finger on the hole and crank the engine is short pulses until that cylinder builds pressure and pushed your finger off (means its on compression stroke)
now look at your pointer and balancer, assuming the balancer is not slipped (or you have an aftermarket piece) then the pointer should be fairly close to 0 on the balancer, turn the engine manually until it lines up. if the balancer is off. your going to have use a screwdriver in the plug hole and rotate the engine backwards and forwards to find the screwdriver's highest point, which will indicate TDC. now would be a good time to place a new mark on the balancer if the factory marks are off now. the new marks may not last long if the balancer is slipping but it should last long enough to get the car fired up and timed dead on before it slips again. if the balancer is slipping replace it ASAP its not good.
there is also a special tool to find exact TDC (if your balancer is off) pretty accuratly but you dont need it really.
so now you have your engine at exact TDC on the compression stroke. pop the cap off the dizzy. and make sure the rotor bug is pointing pretty close to the number 1 terminal. with the plug wires correctly hooked up the rotor will be in the 11-12 o'clock range. where the number 1 will be
if its not pull out the dizzy and rotate it and get the rotor to where it points to the number one terminal. if all is well then it should fire up and then you set your timing.
but remember is very easy to do all this and stabbing it while on the exhaust stroke. will will cause the engine to run like ass, if it even starts at all. usuually it wont ever start, it will crank and backfire.
which makes it sound like it could be a few teeth off, to where you dont have enough adjustment in the dizzy itself to bring it back into correct time.
it sure sounds like a dizzy problem. as for vac leaks, most of the time a vac leak wont affect WOT performance much, unless its a HUGE leak and causing a super lean condition. minor leaks will mostly affect idle quality and etc not WOT. if you cant hear a hissing then there isnt much of a leak. another method is to take some carb cleaner and spray it around the engine. if you see it gather or hear the engine idle up when you spray in a certain spot, then thats where he leak is
good luck
