GT40 intake & Performer head combo-lets see them
  • Thread starter Thread starter MadDAWG
  • Start date Start date Nov 26, 2006
MadDAWG
25
Michigan
Nov 26, 2006
  • Nov 26, 2006
I have purchased a set of 1.9/1.6 valve performer heads. The heads have been ported out to a 1262 gasket on the intake side. This is was supposedly done by a well known shop, but it can't be backed up. My lower intake has also been ported to a 1262 after having the runner legs welded up for reshaping. The car is a 5 speed (2.95 1st - 0.59 5th) 1990 GT. Other goodies include 70mm throttle body and 3,73 gears.
I'm up in the air on cam and exhuast at this point. I'm currently running a e303 with the same intake and ported E7s (190 cfm @ 0.500 lift). I'd like to get some more low end torque becuase of te 0.59 overdrive. I also currently have 1-5/8 FMS shorty headers, but may change of to some 1-5/8 Flow-tech longtubes for which I all ready have the mid pipe for.
I'm curious to see what some other people are running for parts and for ETs and drivability. I'm hoping to run low 12s in the quater and still have a good driver.
Thanks
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 26, 2006
  • Nov 26, 2006
I run the same head..but should note the weak link for the RPM heads is infact the exhaust side, not the intake. I would look at having the exhaust side done before the install. Along with the Eddy heads I run a XE series comp cam and typhoon intake along with every bolt on avalialble...numbers are in the sig. Good luck with what ever you end up doing.
Jim Wyche
27
Collegedale, TN USA
Nov 26, 2006
  • Nov 26, 2006
Edelbrock/GT-40
MD,
My set up is similar to yours. I have the GT-40 intake, E303 cam, Edelbrock Performer heads, long-tubes (please look at the list on my site or in My Garage). It runs 7.6 with a 150 shot or 8.3 N/A in a 302 block. The driveability is fine for an old guy except in bumper to bumper traffic in the summer with the air on. That may have something to do with 14 year-old sensors!
Do you know of anyone using this head and intake on a 347?
Good luck,
Jim
MadDAWG
25
Michigan
Nov 26, 2006
  • Nov 26, 2006
Exhaust side is just as heavily ported as intake. I just didn't know what the gasket number is right now. The guy claimed to have $1200 in the port work alone.
Dman which XE cam are you running? I have an XE274HR but I'm not sure I want to use it for two reasons. The first being I had a TFS stage2 and didn't like it, and second I have 1.7 rockers so the lift gets up there.
Those are the reasons I want to ditch the e303. lol
When ported these can be good (not great) pieces for a 347. On the other hand box stock leaves the performance less than stellar. I should know since I did it. As the saying goes 302 parts = 302 power.
Just an FYI for you Jim if you have not done so all ready I'd highly recomend advancing the e303 cam 4 degrees. It made a world of differance on my car. Just not enough with the .59 OD and 3.73 gears.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Nov 26, 2006
  • Nov 26, 2006
I run the XE270HR-12 but step down to the 1.6 rocker over the 1.7 which I believe will be easier on the valve train due to the aggressive ramp rate of the XE cams..results were excellent IMO.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
