Gt40 Intake
  • Thread starter Thread starter Sledder91
  • Start date Start date Nov 5, 2015
Sledder91
  • Nov 5, 2015
so I am looking at purchasing a gt40 upper and lower, he also has a 65mm explorer throttle body and 24 lbs injector. My question is do I need the larger injectors for this intake or will stock be fine? The car is a 89 Lx bone stock.
Thanks
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 5, 2015
  • Nov 5, 2015
The Explorer tb will need to be modded to work on a fox, maybe it's done already. The 24lbers will need a new maf unit calibrated to them.
Sledder91
  • Nov 5, 2015
The guy did say it was modded for a mustang already. Good to know about the injectors. Ill save those for later on. The stock ones should be fine for just the intake upgrade though eh?
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 5, 2015
  • Nov 5, 2015
Yes.
stykthyn
5,232
2,652
223
gainesville
Nov 5, 2015
  • Nov 5, 2015
The 10hp you might get off just the intake isn't worth the time. If you are getting a good deal jump on it and then wait until you can pair it with a better set of heads.
Sledder91
  • Nov 5, 2015
Yea I figured as much, but it is a pretty good deal so I figured I'd get them now and later do the heads and a cam
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Nov 5, 2015
  • Nov 5, 2015
You could just hit the jy and find an explorer to pull the top end off of. Get heads intake and tb all at once.
stykthyn
5,232
2,652
223
gainesville
Nov 5, 2015
  • Nov 5, 2015
If you're still bone stock a 3g alternator and electric fan are a great bang for the
Sledder91
  • Nov 5, 2015
Yea that was the original plan but I found these on kijiji for a smoking deal and he has blasted and painted everything. What years explorer are the best to get the heads off of? And is the cam worth getting as well?
Yea electric fan and 3G alternator are on the list as well for the junkyard. Just have to research what to swipe them off of.
Disc brakes and better suspension is going to be this winters main focus though
stykthyn
5,232
2,652
223
gainesville
Nov 5, 2015
#10
  • Nov 5, 2015
  • #10
Explorer cam is a truck cam. Leave it.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Nov 6, 2015
#11
  • Nov 6, 2015
  • #11
Great tech info sticky'd at the top of this section, here's all you need to know on the intakes and heads,
Freaky's Official Explorer and GT-40 intake thread. 56k, dont' bother | Mustang Forums at StangNet
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
