I plan to inject my 65 Comet here in the near future and would like to use the gt40 manifold. My question is which one should I use? From what I can see there are 2 different manifolds for a total of 3 different inlet combinations. First is the regular gt40 manifold with the throttle body facing the fender, second is the same manifold with the explorer 90* inlet so that the TB faces forward, or the third is the 94-5 Cobra with the TB at a 30* or so bend cast into it. I know all 3 will physically work, but Ive seen a couple Mustangs with the 'standard' side entry TB and the inlet tube pretty much runs right into the shock before making a bend forward to the filter. I think the Cobra or Explorer would work better, but isnt the Cobra upper a bit shorter or something? Does the Explorer bend even make enough of a restriction to worry about with mildly ported f3ze heads?
...BTW, whats 'PDC'? Ill ask over on VMF, some good guys there too, plus I havent been there in a while. The more I think about it, Ill probably just use the standard setup and get/make an EGR eliminator.
