GT40P Heads?
  • Thread starter Thread starter '88 5FOX
  • Start date Start date Nov 1, 2010
'88 5FOX
29
Seagrove NC
Nov 1, 2010
  • Nov 1, 2010
I picked up a set of these heads pretty cheap and was just wondering if they are worth the time to put them on. I already have the explorer intake and 70 mm tb and egr spacer. I have heard that the bbk headers can be used when putting these heads on. Those i have and know that at least number seven will be hard. Looking for some more opinions. What type of horsepower gains can I expect to see from them if any. Any input apreciated. thanks
Cobra1741
152
  • Nov 1, 2010
i have heard otherwise on the bbk fitting the gt40p heads but not 100% sure. i think you should google gt40p corral.net and do the reading. research will help with your decision =)
T
time only
461
Miami,FL
Nov 1, 2010
  • Nov 1, 2010
It was reported there are Mustang into the 11's with those GT40 heads and intake.
Lot of tuning behind it.
T
t76stang1Day
62
Providence, RI
Nov 1, 2010
  • Nov 1, 2010
its worth it if u get them for a good deal. i payed $300 for gt40p heads, and a gt40 upper/lower intake, and i think that was a good deal, since most gt40 heads go for about 300 bux..u will notice a gain, u can make around 300hp with the right setup..
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Nov 1, 2010
  • Nov 1, 2010
If the heads are good...slap em on. Make sure you upgrade the springs first. Crane and trick flow both make kits that will work.
'88 5FOX
29
Seagrove NC
Nov 2, 2010
  • Nov 2, 2010
Thanks for the help. On allfordmustangs there is a guy with a similar set up. number 7 was hard for him. but they are the same headers as mine. just ceramic coated, I traded an AOD for the heads. going to have them decked and cleaned. any ideas on how this will affect my compression. I will put new springs and stuff on them to be sure. And also, what is the biggest cam if any can be used on a speed density car.
'88 5FOX
29
Seagrove NC
Nov 2, 2010
  • Nov 2, 2010
t76stang, it sounds like u have done this, if so what kind of power gains did you see. Do you have a cam with your setup and such.
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
