Newbie143 said:since you guys brought up the subject of the VT stage 1 cams. Here is a question. I'm Also planing on getting them . For the stage 1 as i understood , there is no NEED to change the valve springs. BUT if i did will i see more gains ???
I mean the cams alone will give about 33+ HP , withought the valve springs. So will it be more if i Also changed the valve springs along with the VT stage 1 cams?
Probably not with a stage 1 cam, the lift on those aren't that dramatic that you would have PTV contact - besides your installer would be able to tell you if there were any problems when doing the install. I would, just for insurance purpouses, get springs too - your doing the heads anyways and might as well do springs for peace of mind IMO.christiesledd said:so with vt stage 1 cams (for n/a) I wouldn't have to do anything else? I could just buy the cams and put them in? I believe you have to have gears and a tune of course, but that won't be a problem. If you just need the cams then that's cheap for the hp gains! Would I have to worry about bending valves?
ProCharger GT said:Probably not with a stage 1 cam, the lift on those aren't that dramatic that you would have PTV contact - besides your installer would be able to tell you if there were any problems when doing the install. I would, just for insurance purpouses, get springs too - your doing the heads anyways and might as well do springs for peace of mind IMO.
Fast02 said:Focus man, focus...
CAMS
HP=Horsepower
Horsepower = teh win
If they had a blower n/a cam dont you think they would market such a stick.
hotmustang331 said:err say again?
..it starts spinning SOOOOO fast, the spring doesnt have enough pressure to keep the rocker tight against the cam and it will kind of JUMP....like having a dirt bike..
....Its really not just the lift thats causing PTV contact with soe of these cams, its more the ground in advance that comp puts in its 270s that are giving people trouble, that and the durration. ....a 110 LCA will keep have both the intake and exhaust valve open at the same time, and a 115 will have much less of this, really to prevent boost from going straight through the inatke and then out of the exhaust...
hotmustang331 said:.. a centri doesnt give you much power in the low RPMs anyways. ... But as far as 8PSI, you probably wouldnt be affected too much, this just gets worse the higher you push the boost. As far as cam choises, the comp 262s seem to be a very good choise for a street car that will get blown later...they have more LCA than VTs stg 1s and SHOULD have CLOSE to the same idle quality....
