guys im having cams installed, and i know the answer to my question depends on cam specs and other variables. i was wondering what kind of power curve your gt had on the dyno after the cams were installed?
what rpm range did you start to feel a power increase?
did you lose low end power in the lower rmp range?
im talking a miled stage 1 cam.
one more thing what is the difference between blower cams and regular spec wise?
theres all kinds of specs intake duration, exhaust duration, then lobe seperation. i got paperwork with my cams but it just cofused me more.
recently read mm and fast fords mag article about this exact and they didnt pic up power until 4000 and up rpm and lost low end.
foxlake said their grind that seems to be the same specs in the mag will have power between 2500-6000? what the difference?
