Ryan's 02 GT said:I just won an Ebay auction of Eibach Pro-kit. I noticed in your signatures none of you have C/C plates. I have read you need them, I have read you don't. Have any of you had any excessive tire wear or bad alignment problems? Thanks
But, figured it would help.Usually with 1.5" drop or less you won't need them. If you get a little more aggresive with your drop you'll definitely need them...Ryan's 02 GT said:I just won an Ebay auction of Eibach Pro-kit. I noticed in your signatures none of you have C/C plates. I have read you need them, I have read you don't. Have any of you had any excessive tire wear or bad alignment problems? Thanks
kennym01 said:Usually with 1.5" drop or less you won't need them. If you get a little more aggresive with your drop you'll definitely need them...
However most people suggest not going any lower then 1" because it might mess up the geometry of the suspension and it will end up hurting performance. Also, if you are going to drop it you may want to shell out the extra cash to upgrade your shocks and struts. With a lowered vehicle the stock shocks and struts will not handle the lower car as well as an aftermarket shock/strut will...just a suggestion.
