I never did dyno when I instelled Trick Flow TW heads ,and I tryin do shift points
So guys plese post your dyno sheets N/A ONLY
, with speaker box in the trunk and full tank of gas car weight 4100lbs, cobra259 said:You are not making any power past 5600. I just did another dyno tune 2 days ago. I'm running AFR 165's, cam , ported Cobra upper and lower,75mm Pro-m and 65mm t/body and a bunch of other mods as well. I did 288rwhp and 322rwtq. My hp stops going up @5500 RPM
cobra259 said:I know you have tw heads....the tw and afr flow pretty close to the same. I've got a custom cam with 544 lift and 275 intake and exhaust dur.
Just trying to help,since I just did a new dyno tune.
