guys with upr x pipe i need some help!!!
RED98Z28 said:
where does the little peice that they send with the pipe actually go?
thanks
-kenny-
It goes into either the passenger side inlet or driver's--I can't remember--but I believe it's the driver's. You should be able to tell when you start bolting it up. It slides into the piece that will be bolted up to your exhaust manifold.
If I remember, there's a gasket on the passenger side, but on the driver's side, the exhaust manifold sits down into the inlet of the X pipe. That's where that little sleeve comes in.
RED98Z28 said:
yeah it is the drivers side where the manifold meets the pipe from what i can tell. I just wasnt for sure. If anyone is 100% sure chime in please!
That's where it goes. I'm 100% sure now, because when I got my UPR X, I wasn't sure either, so I had to ask around myself. That sleeve acts sort of like an adapter. If you notice, the diameter of your exhaust manifold is smaller than the opening for the X. The sleeve helps insure a tight fit.
