I ended up getting TFS 170 heads and I have a few follow up questions as I piece together the rest of the package...
-I bought the assembled heads which have the 1.46" valvesprings. When purchasing roller rockers, should I consider upgrading to the larger 7/16" studs and purchasing corresponding rockers, or will the included 3/8" stud be ok given the capabilities of my valvesprings? As I mentioned before I may at least explore the idea of a custom cam. So I guess I want to know if I should worry about the weak link--the springs or the studs? (Or am I being crazy?)
-As for the roller rockers, is there any stud mount rocker that is exceptionally good or bad? Ie something I must have or must avoid? Steel vs Aluminum? Any brands? I've noticed the Trick Flow 3/8" set as well as the Comp Cams 17043-16 set. Both are aluminum and bother are 1.6 ratio.
-For lifters, are the FRPP ones offered on Latemodel Restoration good parts? They offer a standard version ($123) and a performance version ($199). Is there any real life difference? Any other brands? I assume I should change these when I do everything else, but if that's not the case let me know.
-For the timing chain, is the Comp Cams Magnum chain listed on LRS ($40) for some reason inferior to the FRPP ones which cost more than double?
Thanks
