Hey guys, I just about have all the pieces now for my swap but don't have a gasket set yet. I am using ported e7's and a cobra intake, so what gasket set would you recommend me using? Is there a set that gives every gasket I would need? I never really looked into it much at all. Please let me know what brand and part number you have used and whether you liked it or not.
Also, if my lift is going to be .544" should my valve springs be able to handle a certain amount more than that? I heard somewhere that your valve springs should be able to handle about .050" more than what you are going to use. I don't know exactly what my springs can handle, but the machine shop I am going to take them to said they could check that when I get the valve job. They are dual springs with damper, so I assume they can handle enough, but I want to be sure.
Oh yeah, I haven't torn the motor apart yet, but I imagine there will be some carbon build up on the pistons. What could I use to remove that? Should I just leave them alone, or should I get rid of the build up?
Thanks for the replies in advance,
Chris
Chris
