h/c/i
  • Thread starter Thread starter 94excoupe
  • Start date Start date Mar 21, 2010
First Prev 2 of 2
HankyGT
81
Warren, OH
Mar 22, 2010
#21
  • Mar 22, 2010
  • #21
Or he can use his low milage shortblock and have alot of fun on a budget renting a flycutter and throwing it all together.
We made 310/330 rwhp with a 'crappy' f-cam using a 1.6 rocker vs 1.7s and ported gt40s on my brothers cobra. It may not be the 'best' cam, but I'd say its far from garbage. Last time I checked a custom grind was $300-400, pistons are another $450 for anything decent, rings, gaskets, bearings. You can snowball that project another $1500 to make 10-20 hp or you can go have some real fun on a budget and likely make more power than most anyhow.
As far as I have read this; he hasn't installed a thing so everything is going to come off anyhow. It takes all of 10 min to check PTV. I know your irked since I quoted you, but your reference had zero relevance.
BlackVert
5,589
9
98
Bethesda, MD
Mar 22, 2010
#22
  • Mar 22, 2010
  • #22
if you don't have the AFR 185s yet, you might consider 165s instead as they don't require any flycutting to make them fit.
if you already have them, what will you do, rebuild the other engine to get the right pistons in there so you can use the 185s? does that fit in the budget?
the thing i'm not following here is your goal and budget. sure the f-cam will work, and it is hard to argue with the price, but with the cam being such a key part of the bigger picture, and the pain it is to replace it later, i would think that of everything, you would want to make sure that is the most correct thing you get.
if it were me, i'd probably trade/sell the 185s for 165s and spend a few extra $$ on the cam and put it all on the low mileage motor already in the car.
9
94excoupe
58
#23
  • Mar 22, 2010
  • #23
well thing is im gettin a awesome deal on the heads. i didnt know at the time it wouldnt clear. i can stretch the budget to buy a cam and pistons but which ones go with this setup. but i may try flycuttin just havent got anything set in stone yet
HankyGT
81
Warren, OH
Mar 22, 2010
#24
  • Mar 22, 2010
  • #24
I completely disagree with the purchasing of 165s in place of the 185s. Do NOT limit yourself later by your heads; I wish I had done differently when purchasing my own. Are you guys really crying about cam swapping a 5 liter? On a mustang board no less?
What does it take; all of 3hrs?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 22, 2010
#25
  • Mar 22, 2010
  • #25
Adam95GT said:
exactly why he shouldnt mess with stock pistons... if your going to pull the heads to check PTV... and to possibly Fly cut. You might as well just get some new pistons rings and bearings
I'm with Hanky on this one. Flycutting the stock pistons really isn't that big of a deal. You can buy the tool from Lunati pretty cheap. If you change the pistons, the engine has to come out of the car, and it's going to cost a good bit of money just in machine work.
Kurt
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 22, 2010
#26
  • Mar 22, 2010
  • #26
Sorry, Isky makes the tool, not Lunati. Here is a helpful bit on how to check and cut if necessary.
Checking Piston to Valve Clearance - FORDMUSCLE webmagazine
Here is the tool you need.
Isky Racing Cams NP1132 - Isky Racing Cams Engine-Related - Overview - SummitRacing.com
Kurt
Adam95GT
2,564
Burlington, NJ
Mar 22, 2010
#27
  • Mar 22, 2010
  • #27
Kurt
Guy doesent really sound like he knows what he is doing enough to perform it and if you have to pay someone else to do it its almost not worth it... (based on questions asked if he would clear with a 351 instead looks like he would do anything just to make a set of heads work.) If you have a spare block just put a decent set of aftermarket cheap pistons in there. Its not like parts are expensive right now.
But thats just my opinion
He doesent really seem set in stone on anything so i think people are just trying to lead him in the safe cookie cutter mustang.
But like i said its just my opinion.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 22, 2010
#28
  • Mar 22, 2010
  • #28
Brokeness is a learning tool. You figure out how to do all kinds of things when you are broke, and building an engine on a budget. I understand and respect your perspective though.
Kurt
Adam95GT
2,564
Burlington, NJ
Mar 22, 2010
#29
  • Mar 22, 2010
  • #29
Kurt
My engine was budget you defiantly learn that way
9
94excoupe
58
#30
  • Mar 28, 2010
  • #30
your right i have no idea how to fly cut anyting or what cobinations work well together. however i do haved the know how to build a motor and check the ptv clearance. i have asked numerous times what cam and pistons i should use and everyone keeps going back and forth about whether i should fly cut or not. since i dont know how to do it thats not the route i plan to take. any suggestions on cam and pistons are greatly appreciated. o and ill be using a 351w blosck for my starting point
BlackVert
5,589
9
98
Bethesda, MD
Mar 28, 2010
#31
  • Mar 28, 2010
  • #31
most aftermarket pistons are notched for the heads. use a tfs stage 2 cam
Adam95GT
2,564
Burlington, NJ
Mar 28, 2010
#32
  • Mar 28, 2010
  • #32
Correct... just decide on flattop, dome, dished pistons and if you want forged or hypers.
TFS-2 or any off the shelf cam without crazy lift should be fine.
Are you planning on NA, Nitrous, FI ???
Im assuming your going to go with a roller 351 and not a flat tappet ??
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Mar 28, 2010
#33
  • Mar 28, 2010
  • #33
TFS 2 cam is a roller cam.
Kurt
Adam95GT
2,564
Burlington, NJ
Mar 28, 2010
#34
  • Mar 28, 2010
  • #34
Kurt
Thats y i was asking just making sure hes got a roller block. i mean its not a big deal if not just wanted to be sure he knew there was a difference.
9
94excoupe
58
#35
  • Mar 29, 2010
  • #35
hopefulle i can find a mid 70s block, thats what i hear is the strongest. buy i may try to find a roller block just depends what i can find in my area. i plan on boost sometime in the future b ut want something fun til funds allow it.
First Prev 2 of 2
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
