H pipe length
rd
3,316
63
109
Ocean Springs MS
Do h pipes and x pipes vary in length a lot?
I had to shorten my Flowmaster muffler inlet pipes 2 inches to fit between the end of the x pipe and were the tail pipes fit, so the tailpipes would clear the axle?
Gotta find the receipts, since I am not sure that I got all Flowmaster parts. I ordered an h pipe and an x pipe showed up so I installed it.
Hopefully a couple more nights and she will be up and runnng again.
every manufacturer is different, some people have fitment issues, some dont. Its like a luck of the draw kind of thing. If you have an modified catback then that could be your problem. The x and h is supposed (keyword supposed) to fit into place of the stock h pipe,
I thought the same thing when I swapped out different brand midpipes. My flows wound up poking out the back too far or too short,,,, until I figured something out. You can fix this by pushing up on where the mid pipe meets your catback at the collars. They are adjustable in a sense. In my case i was too short so I use my floor jack and jack up at where the 2 pipes met and made it where I wanted it then tightened down the collars. In your case, you gonna have to bring the joint down some.
Shortthrow has a got a point. It is adjustable 'to a point' by keeping things level. It could throw in another inch or so, potentially.
If a stock catback or aftermarket catback has had another pair of mufflers welded in, that will affect the length as well.
I find that Mac and BBK are pretty close in length.
An H and X pipe should be the same length from the front to the back (roughly) where the they connect to the headers and/or catback.
I ended up with a UPR x pipe and Flowmaster American Thunder mufflers and tailpipes.
I cut 3 in pieces out of the muffler inlet tubes and put 2 1/2 in od/id connectors back in, so they ended up about 2 in shorter.
Its on there, still got some issues. but it sounds great!
