H pipe problems
  • Thread starter Thread starter leakyfaucet
  • Start date Start date Mar 31, 2004
L
leakyfaucet
273
North Carolina
Mar 31, 2004
  • Mar 31, 2004
I recently purchased a Mac off-road H pipe to replace the H pipe I had on at the time, a MAC O/R pipe that I had 2 cats welded up to for e-check.
I tried to put it on, but it was about 3 inches too short. I put it on top of the old MAC H pipe and yep, about 3 inches shorter. I ordered it from e-bay and it was supposed to be for a manual transmission, like I have. I think the rear exhaust I have on the car is for an automatic then. Are MAC H pipes for automatics longer?
So I had to put the old catted MAC H pipe back on. When I went to slide them over the studs on the ends of the longtubes, they wouldn't go! It appears the studs on the longtubes point outward and miss the holes in the H pipe clamp by about 1/16". How should I go about correcting this? Hammer the studs and hope they bend back into place? Can you take pliars and unscrew them and screw in new ones? I suspect they might be bent.
Any thoughts? (My #1 problem right now is getting the old H pipe back on)
4dStang
Banned
Oct 23, 2002
718
Near St Louis, Missouri
Mar 31, 2004
  • Mar 31, 2004
You can always remove the header, fix the bolts and then slide it back in. I have been under my car at least ten times switching pipes and I know the crap you are talking about.
RYC CUKR
1,437
Orlando
Mar 31, 2004
  • Mar 31, 2004
If worst comes to worst for the studs on the heads take two nuts and thread them onto the studs. Tap on the flat sides of the nuts with a hammer. Since you only have to move them say a 16th of an inch I think that will work. I had to do that to the studs on my H pipe when I installed my Magnaflow cat back. other than that you will probably have to take the headers out to have them fixed.
fivelitercoupe
132
Longwood, Florida
Mar 31, 2004
  • Mar 31, 2004
The manual and automatic h-pipes are the same length but are just bent a little different for clearence issues. But people do all kind of weid things with exhaust, that could throw the lengths off and things like that. Good luck with it though and hope you figure it out....
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
F
H-PIPE WIDTH
  • forango
  • May 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 28, 2025
LILCBRA
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
