Drivetrain Had An Issue With My Clutch And Quadrant...now I Cant Drive It
91gte303
144
18
28
Lake city,SC
well...im new to the mustang crowd and id like to say from my personal experience,that is you have a stock 2 pc. quadrant and you have owned the car for longer than 10 seconds,put the better quadrant in there,at least.
anyway....so here is my story and hope you can help me figure this out before i drain my bank account.
so a friend of mine has been asking me to take him for a ride.so i drove it like i stole it. notice shortly there after ,on the way back to his house,that i was having to move the shifter more to get it in gear. stopped in the road and checked some stuff. moved that damn rubber boot out the way of the shifter and then put it back in gear and continued on to his house. shifted fine,clutch was still working fine. got to his house,cut it off and bs'ed for a wile. then when i went to leave,pressed the clutch pedle only for it to pop the quadrant and no clutch movement. messed with it and found that,after i kept messing with it,that the teeth on the quadrant are all but gone.either way, it seemed like the throw out bearing was binding up and wouldnt move anything. keep in mine...the bastard was just working about an hour before. now im wondering wtf happend. i noticed that when i started the car, i heard a liht knocking every so offen just before i popped the damn quadrant and shut the car off.
i have a z-class t5 and it was,so im told, a new clutch kit. there was no noise before hand.
W....T...F people.....please help.
Replace the stock quadrant and cable. After you have the replacement parts installed and adjusted, then look at other areas.
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works. To release to tension of the stock quadrant, use a screwdriver to lift the ratchet paw up and out of engagement with the quadrant teeth.
A binding clutch cable will make the clutch very stiff. If the cable is misrouted or has gotten too close to the exhaust, it will definitely bind. The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
Clutch pedal adjustment with aftermarket quadrant and cable: I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
Adjustable clutch cable tips:
Loosening the cable adjustment nut (throwout bearing arm moves to the rear of the car) moves the disengagement point towards the floor.
Tightening the cable adjustment nut (throwout bearing arm moves to the front of the car) moves the disengagement point towards the top of the pedal.
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just as good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable, firewall adjuster and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
See Summit Racing - High Performance Car and Truck Parts l 800-230-3030 for the following parts.
Ford Racing M-7553-B302 - Ford Racing V-8 Mustang Adjustable Clutch Linkage Kits - Overview - SummitRacing.com Cable and quadrant assembly $90
The Ford Racing Adjustable cable is available as a separate part:
Clutch Cable, Adjustable, Ford, Mercury, 5.0L, Kit FMS-M-7553-C302_HE_xl.webp
[url=http://www.summitracing.com/parts/SDA-555-7021/]Steeda Autosports 555-7021 - Steeda Autosports Firewall Cable Adjusters - Overview - SummitRacing.com
Steeda firewall adjuster. $40
Fix for the quadrant end of the cable popping out of the quadrant when installing a replacement cable courtesy of Grabbin' Asphalt
imag0825-jpg.85883
[/url]
