seting idle
Is yours a mass air car?
If so:
1) Disconnect the battery (and the IAB valve) for 20 minutes.
2) Reconnect the battery (but not the IAB valve), start the engine and adjust the idle.
3) wait 2 minutes, connect the IAB valve, turn off all accessories, start the engine, let it idle for two minutes.
4) Shut off engine for two minutes.
5) Turn on all accessories, start the engine, let idlefor two minutes.
I don't know if this works for Speed Density cars.... Not sure but I don't think so!
Some say this works too:
Make sure the engine is fully warm. Disconnect IAB motor while the car is running. Set the rpm where you want it. Turn the car off, reconnect the IAB and start the car. Your done. I never had to do a relearn procedure anytime i adjusted fords minimum air flow.
Set TPS voltage to .98v (w/throttle closed)
