Hard Fuel Line install-Impossible?
  • Thread starter Thread starter BullittStangV8
  • Start date Start date May 16, 2007
BullittStangV8
1,104
NJ
May 16, 2007
  • May 16, 2007
I've spent at least 5 hours trying to figure out how to get my new hard fuel line into my 65. The old one I cut into 3 pieces to get out. I simply cannot get it in. I cant get it to cross the break cable lines in the places it needs to. How did you guys get yours in?
66HertzClone
428
Central New Jersey
May 16, 2007
  • May 16, 2007
From behind the left side of the car, I fed it over the axle and then pushed it as far forward as possible. I went to the front and used the mounting clamp to attach it to the inner fender. I lined up the line along the lip for the gas tank and secured it with the mounting clips. All I did then was move along the line bending as needed to shape it into position. I placed the mounting clips on it as I went along so it would fight back. As I remember it really wasn't that difficult, but then, there was no driveshaft or exhaust system in the way.
fasttback
471
Northern CA
May 16, 2007
  • May 16, 2007
Did it on a 1966 3/8 in stainless version. Started off with the car lifted off the ground with jacks (do not lift the rear with jacks under the rearend, you may need the extra room). Exhaust was removed, but the rear shocks were still on. Plug the new fuel line to prevent material going in the line. With the line under the car, I fed it back over the rearend in a twisting motion. The line will hit just about everything, but it can be bent slightly to help accommodate the placement. After rear section is in position leave it loose so you can position the front through the suspension and engine compartment. Bolt and clamp and your ready to go.
coolblue65
1,224
Algonquin, IL
May 16, 2007
  • May 16, 2007
This post has good timing- I am waiting for my new fuel line to show up this week.
BullittStangV8
1,104
NJ
May 16, 2007
  • May 16, 2007
well...i fed it up under the car from behind, and its starting to get into place. everything is fine in the front, but in the back the line needs to go above the break line to the rear, but around the shock. I dont think its possible for me to make it fit without pulling it all out. I may just disconnect the brake line, put the fuel line over it, and reconnect the brakes.I need to bleed the brakes anyways.
tx65coupe
Jan 13, 2009
  • Jan 13, 2009
Where is the V8 fuel line supposed to be routed in the front in the engine compartment? All I had for reference before is my I6 line.
BarnStang
1,260
Hagerstown, MD
Jan 13, 2009
  • Jan 13, 2009
It crosses the frame where the toe board meets the front floor pan and goes outside the frame rail and runs up the frame, to the LH front fender apron. THere is a hole that the end sticks through. Then a rubber grommet centers it.
G
geordie
576
  • Jan 13, 2009
I submitted a similar thread on the same subject recently. I am going to have to cut my old line into sections to get it out. My problem is I can't see how to get the new line underneath a rear suspension brace that runs from one side of the car to the other just in front of the fuel tank. It looks as if the brace was installed before the fuel line went in by the PO, judging by the paintwork, but I can't see how he did it.
Capt Dan
237
College Station, Texas
Jan 13, 2009
  • Jan 13, 2009
What I found to work for me was to not cut your old line to get it out.
I don't remember what all I had to take off to get the old line out in one piece, but once it was out of the way the new one went in fairly easily. If you cut the line, it is harder to figure out.
tx65coupe
Jan 14, 2009
#10
  • Jan 14, 2009
  • #10
Thanks for the input. I had no idea that it was routed outside the engine compartment and then back in. Does it have any mounting clips or tabs between the grommet and where it goes under the frame rail?
BarnStang
1,260
Hagerstown, MD
Jan 14, 2009
#11
  • Jan 14, 2009
  • #11
Yes, at least two bolted clips. We get our clip kits from kentucky Mustang. Kentucky Mustang 1-888-861-0176
Has al the clips fot the fuel and brakes lines. Most complete kit I have found. And I keep a bag of used clips to media blast if needed. I never seem to have enough.
jerry S
1,365
52.22N 5.12E
Jan 16, 2009
#12
  • Jan 16, 2009
  • #12
why not just use a rubber line?
Tim65GT
1,149
West Texas
Jan 16, 2009
#13
  • Jan 16, 2009
  • #13
I bought 3/8 steel line and bent mine myself. It is all one piece and routed around the outside of front frame, similar to stock.
Here is a picture.
The clip on the left is stock and the one on the right is additional.
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
