Hard start when hot
  • Thread starter Thread starter 94gt_vert_proch
  • Start date Start date Jun 2, 2008
9
94gt_vert_proch
10
  • Jun 2, 2008
Hi i have been chasing this problem for 3 years and still no luck. i crank it 4-5 times before it will start. Sometimes it will run for like a second at like 400rpm then die. the only way to start it is to keep the pedal on the floor and i need to do this 3-4 times to get it running. it will start hot if you shut it and turn it right back on but if i let it sit for a few mins like at a gas pump forget it. i have tried some start fuel settings with my new pms and no luck. Things i repleced over the years (computer dizzy tfi iac upgraded to crane ignition cap rotor plugs wires coil battery and summit starter ) all with no luck. Other then that the car runs and idles fine. Does anyone have a clue? i thought it was the 60 lb injectors but i even put the stockers in and the same problem. Please let me know what you guys think i am going crazy.
Thanks
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
