Hard start when hot
94gt_vert_proch
10
Hi i have been chasing this problem for 3 years and still no luck. i crank it 4-5 times before it will start. Sometimes it will run for like a second at like 400rpm then die. the only way to start it is to keep the pedal on the floor and i need to do this 3-4 times to get it running. it will start hot if you shut it and turn it right back on but if i let it sit for a few mins like at a gas pump forget it. i have tried some start fuel settings with my new pms and no luck. Things i repleced over the years (computer dizzy tfi iac upgraded to crane ignition cap rotor plugs wires coil battery and summit starter ) all with no luck. Other then that the car runs and idles fine. Does anyone have a clue? i thought it was the 60 lb injectors but i even put the stockers in and the same problem. Please let me know what you guys think i am going crazy.
Thanks
