Hard to start 92 GT
CHM92stangman
9
Hello. I hope someone can help me and figure out what is up with my 92 GT. When I start it first thing of the day it starts but dies. Today it took about 5 times today to get it to run and even then it would not take gas without backfiring when trying to give it gas and would not idle very well. Once it warms up it will take gas and run great but the next day it will do the same thing. I hope someone can help me figure it out . Thanks guys.
I have checked fuel pressure and it was about 38psi at idle jumped to about 45 when giving it gas. Changed fuel filter, cleaned mas air flow , tried another IAC valve(used) and didn't really change anything. Have not pulled codes yet and going to try to get that done tomorrow. I did notice that two weeks ago when it was really cold out(about 10-12) it started right up but today when it was close to 40 it was a major pain in the a**.
I would think your IAC is bad or on its way out. When you put the other IAC and said it didnt really change anything. Did you try to start it in the morning or the 1st time in the day or just swap it out and started it
When I changed it I had already had it running that day and it didn't seem to change anything then the next morning when I started it it done better and stayed running the first time but it was really cold that morning. Then today it did the start die start die about 4 or 5 times so I gave it gas as soon as it started to keep it going and it done the backfiring thing . LOL if I had any hair on my head I would be pulling it out right about now.
any chance it could be moisture in the dist cap? on the colder day there could have been less humidity in the air to get into a cracked cap. just throwing out an idea. had a similar problem once. A buddy told me to change the cap & rotor. It fixed mine.
I was just thinking about that as a matter of fact tonight. I know my buddy I got it from put a new cap(upper) but not the lower so I was wondering if that had something to do with it. I'm going to have codes pulled tomorrow and put a new upper and lower cap on as well as check the IAC again. Thank you everyone and if anyone else has a clue as to some things that it might be let me know I will post what I find out tomorrow .
The backfiring is due to a lean mixture problem or vacuum leak. Dumping the codes will spot ACT and ECT problems IF you dump them on a warm engine.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Thanks again everyone for the input. Got the codes today and says that I have a faulty TPS sensor and MAP sensor so going to pick those up in the morning and clear codes and put new parts on and see how it goes.
FWIW, you don't have a MAP sensor per se (the parts store guys might not list a MAP for your '92).
You might want to be sure the BAP's electrical connector is seated and check the TPS baseline. If the latter is reading a bit above or below 1.0V, that can generate a code. The issue in such a situation can sometimes be resolved without the need for a new component.
List the code numbers the code dump gave you. I have 5.0 Mustang specifc code definitions that tell you what's wrong and how to fix it. That can save you lots of $$$, because sometimes it is an adjustment or wiring problems and not a faulty sensor.
Update. Had a friend work on the car and they found the wires to the egr and tps sensor was broken and fixed them so now there are no more codes or check engine light . Alas the car is still acting funny on first start up and for the first 5 to 10 minutes. It still starts but dies about 2 to 3 times before it will stay running and then it doesn't want to really take gas without backfiring in the intake some. Had all the fuel checked(pressure etc.) change the coil, cap, rotor, plug wires, plugs. Had the ignition module checked and said it was ok . I did notice that the other day when I started it , it did better and it had been warmer and dryer(for a change lol) then it has been and thinking either i still have some wires messed up or need to look into getting a whole new wiring harness . If anyone has any ideas give me a shout. Thanks guys
Check ECT.
One way I did it was to dump the codes on a stone cold engine. I usually got an ECT out of range code on a cold engine. Once I was working on a guys' truck exhibiting similar symptoms and was getting a code 11 (actually 111 on that particular deal...3 digit) meaning all clear but the engine was ice cold so it should have dumped a 116. Found sensor wire was cut due to engine install from previous owner...fixed the wire...cold naturedness and backfiring was gone. Also was getting a 116 on a cold engine just like it should have. That was a '95 F150 with a 5.0 and a M5OD-should be same principle.
Just a thought.
