Hard to start in the morning
93Stang23
38
Ever since it's been colder outside my car has been harder to start. Only on the coldest days will it have trouble, when I try to start it, it will sit there and shake while i have the key turned...after about a minute of giving it gas while turning the key it finally turns over. I've already replaced the fuel filter, fuel pump, and the coolant sensor(it was reading -32 degrees and we thought the sensor was the problem before and it did work for a while and now I have the same problem) if anyone has any ideas to what the problem might be I'd appreciate it, thanks
The plugs were replaced about 5 thousand miles ago, the wires could use a change, and I don't even know how old the cap and rotor is, and it still cranks at normal speed....what i don't understand is when in the morning when i turn the switch i don't hear the fuel pump kick on, but anytime later in the day i hear it kick on and it starts up just fine
Unless it is an "Optima" brand no battery is truly manitinence free.
Pry off the litttle caps with a flathead screwdriver and see if the battery cells are low. That is a pretty common problem and can cause hard starting. That is always one of the first things I check in a situation like that.
If they are low just add water to each cell until they are all about the same level.
