thanks a bunch it worked like a charm but now i cant get the balancer itself off. i have the puller but i get to a point where it wont turn any longer, should i keep giving it hell or am i useing the tool wrong?S/CBlack95GT said:Put it in 5th gear.
17yrOldStanger said:ok, heres how it should go down:
-Remove your fan
-Move the overflow tank out of the way of the fan
-Break the crank bolt loose
-Use 2-3 small bolts and screw them into the balancer so they hold the brace in place
-put the huge center bolt in and use the sharp tip on the bolt
-crank away at it until the balancer pops off the key way
-Pop the new one on and get nasty
govtmule said:ok well im on step 5 but i didnt take out the fan or overflow tank, is the imperative?
