  • 1994 - 1995 Specific Tech
Harmonic Balancer
  • Thread starter Thread starter KTD SC
  • Start date Start date Dec 27, 2004
1 of 2 Next Last
KTD SC
99
New York
Dec 27, 2004
  • Dec 27, 2004
My harmonic balancer is starting to crap out on me so i need a new one asap, i just wanted to ask where i can get a good one for a good price, any help would be appreciated.
thanks
E
ef200098
123
  • Dec 27, 2004
how do u know if your balancer is going out?? sorry for the newb ?
gcomfx.com
3,690
Republic, MO
Dec 27, 2004
  • Dec 27, 2004
Stock ones available at most parts stores....
KTD SC
99
New York
Dec 27, 2004
  • Dec 27, 2004
My cars idle isnt that smooth anymore, so i took a look under the hood and the harmonic balancer is wabbling, so i guess thats a good enought sign for me.
pleasehelp
686
Poplar Grove, Il
Dec 27, 2004
  • Dec 27, 2004
When you see a rubber thing inside of it sticking out. Some guys will tell you not to bother putting a stock one back in. I wouldn't recommend it.
M
Meangene21
187
Chesterfield VA
Dec 27, 2004
  • Dec 27, 2004
I had to buy an OEM one from Ford. No auto parts store had one...
gcomfx.com
3,690
Republic, MO
Dec 27, 2004
  • Dec 27, 2004
I got mine on a sunday at Autozone.... only way in the world I could get one on a Sunday when my car was broke down.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 27, 2004
  • Dec 27, 2004
I believe GTJake is selling a romac 50oz balancer for a good price. Might as well put a real balancer on it while your there.
Numbles
998
Chicago, IL
Dec 27, 2004
  • Dec 27, 2004
I just put a romac on last week. Got it off of ebay. Car idle's smooth again. The rubber on the old one had almost fallen all the way out by the time I dropped it off at the shop.
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Dec 27, 2004
#10
  • Dec 27, 2004
  • #10
Pick yourself up a Pioneer balancer from strokermotor.com Its a nice piece and very good price. I think mine came to $180 shipped to my door which is about $100 cheaper than the romac, and just about as nice. http://strokermotor.com/DESCatalog/page-4-SFI.html you have to call to order one.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 27, 2004
#11
  • Dec 27, 2004
  • #11
Are you supposed to feel any rubber sticking out behind the balancer? I can feel what I think is a ridge of rubber sticking out on the back of my balancer. It feels pretty even, so I'm not sure if I'm checking the right spot.
This should be on topic anyway, if only as advice on removing the harmonic balancer. I don't plan on hijacking this thread.
I've already decided to replace the balancer anyway. Has anyone been able to loosen the one bolt holding the balancer on? I didn't have enough room for my impact wrench to fit, and I don't want to drain my radiator, so I need to buy shorter sockets. The air ratchet didn't have enough torque to budge it. I tried to use a breaker bar, but I can't keep the balancer from rotating. I left the crank pulley and the belt on, but it still slips.
Any suggestions?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Dec 27, 2004
#12
  • Dec 27, 2004
  • #12
Put the car in 5th gear and it will not move. I did mine a few months ago and that's what every one here recomended to do and it worked like a charm. I used a 3/8 ratchet and muscled it out of there it did not turn.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 27, 2004
#13
  • Dec 27, 2004
  • #13
Try sticking your car in 5th gear if its a manual. I did that and an impact and that nut came right off, so maybe it'll come off with a breaker bar that way too
AznStanger3v
2,026
Northern VA
Dec 27, 2004
#14
  • Dec 27, 2004
  • #14
if you are feeling daring, hook a 1/2 inch drive ratchet on the bolt with a breaker bar and have a buddy *bump* the ignition. itll break on loose
Grn92LX
Fidanza Man!
6,819
64
129
New York
Dec 27, 2004
#15
  • Dec 27, 2004
  • #15
5th gear like they said, have someone hold the brakes hard and use a breaker bar or a home made breaker bar ( 4' pipe over my 1/2" drive ratchet ) and it'll loosen easily with no issues.
RIO5.0
6,892
N.H.
Dec 27, 2004
#16
  • Dec 27, 2004
  • #16
160.00 for a Romac...50 OZ...which is what you need.....Check it out....
http://www.corral.net/forums/showthread.php?t=586570
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Dec 27, 2004
#17
  • Dec 27, 2004
  • #17
No good for me on 5th gear, I got an AODE. I tried putting it in Drive, 1 and 2 with no luck. Would putting the tranny in reverse be just as good, or would it put stress on the tranny?
Before I got my air compressor & tools, I tried a breaker bar over a ratchet. That's when it started slipping. I puit a ratchet extension in the power steering pulley, so the belt doesn't move. But the crank pulley slips on the belt.
I'll try the impact wrench before "bumping" the engine over, but it's an option.
1105
May 3, 2003
3,841
Daytona Bch, FL
Dec 27, 2004
#18
  • Dec 27, 2004
  • #18
Just an idea... If it spins clockwise looking at it from the front, stick the socket on there and a breaker bar, let it breaker bar touch the ground to the right of the pulley then bump it a little to see if that'll break it loose?
9
94stang-lover
62
#19
  • Dec 27, 2004
  • #19
this what my bnalancer looked like
i went with the romic balancer from ebay
J
jesserose17
219
Southern CA
Dec 28, 2004
#20
  • Dec 28, 2004
  • #20
I did mine a few weeks ago - remove the flywheel access cover, and put 14mm socket (I think that's the size) on one of the converter bolts, leave them on... while you slowly rotate until the socket hits and stays put, then give it all your muscle to loosen the bolt. It worked for me.
1 of 2 Next Last
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
Acceleration Vibration
  • Blown02svt
  • Dec 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
General karthief
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
