Harmonic Balancer
Are you supposed to feel any rubber sticking out behind the balancer? I can feel what I think is a ridge of rubber sticking out on the back of my balancer. It feels pretty even, so I'm not sure if I'm checking the right spot.
This should be on topic anyway, if only as advice on removing the harmonic balancer. I don't plan on hijacking this thread.
I've already decided to replace the balancer anyway. Has anyone been able to loosen the one bolt holding the balancer on? I didn't have enough room for my impact wrench to fit, and I don't want to drain my radiator, so I need to buy shorter sockets. The air ratchet didn't have enough torque to budge it. I tried to use a breaker bar, but I can't keep the balancer from rotating. I left the crank pulley and the belt on, but it still slips.
Any suggestions? :shrug:
5th gear like they said, have someone hold the brakes hard and use a breaker bar or a home made breaker bar ( 4' pipe over my 1/2" drive ratchet :D ) and it'll loosen easily with no issues.
No good for me on 5th gear, I got an AODE. I tried putting it in Drive, 1 and 2 with no luck. Would putting the tranny in reverse be just as good, or would it put stress on the tranny?
Before I got my air compressor & tools, I tried a breaker bar over a ratchet. That's when it started slipping. I puit a ratchet extension in the power steering pulley, so the belt doesn't move. But the crank pulley slips on the belt.
I'll try the impact wrench before "bumping" the engine over, but it's an option.
Just an idea... If it spins clockwise looking at it from the front, stick the socket on there and a breaker bar, let it breaker bar touch the ground to the right of the pulley then bump it a little to see if that'll break it loose?
this what my bnalancer looked like
i went with the romic balancer from ebay
I did mine a few weeks ago - remove the flywheel access cover, and put 14mm socket (I think that's the size) on one of the converter bolts, leave them on... while you slowly rotate until the socket hits and stays put, then give it all your muscle to loosen the bolt. It worked for me.
