harmonic balancer?
AUcobra94
59
I bought a balancer(sfi) on the corral a couple of weeks ago and it wouldnt fit my car. It hit one of the water pumps bolts and woulnt go on far enough for the belt to line up. The pully wouldnt fit on it either, but it has 302 HO stamped on it and the bolt pattern for the pully is right. Does the fox body and sn95 have different balancers? Thanks
I have read (from Brandon, et al) that sometimes on the SN cars, one has to grind the water pump bolt a little bit.
This is the one I got and it works fine
http://cgi.ebay.com/ebaymotors/82-9...ryZ33616QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You don't want to ruin anything by grinding too much off of anything. The bolt shouldn't be sticking out much more than the actual water pump though? Are you sure it's hitting the bolt, or is the notch in the balancer and the key in the crank just a tiny bit off? 1mm will do it....I'd look at the notch on the inside of the balancer and see if it looks like it has any damage to it....just a thought. Good luck!
