  • 1994 - 1995 Specific Tech
Harmonic Balancer
  • Thread starter Thread starter Guero
  • Start date Start date Mar 22, 2007
Guero
2,148
Mar 22, 2007
  • Mar 22, 2007
I was bored and did a search. A thread came up on HB. Went tru it and saw some of you are running aftermarket ones. Im running 1 from checkers which is a stock replacement. Is that bad??? Whats the difference from each other???
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 22, 2007
  • Mar 22, 2007
Some HB's have a SFI rating which means two things ...........
1) They cost more
2) They'll stand up to more abuse
and
IIRC ... Some drag racing classes require them
I killed my little OEM HB very shortly after doing quite a few 6K+ rpm
3rd gear passes dialing in my final WOT fuel ratio
No Doubt In My Mind ... high rpm kills the stocker
Grady
Guero
2,148
Mar 22, 2007
  • Mar 22, 2007
How do you know if its messed up??? I've done quite a few high rpm runs.more than a few lol
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Mar 22, 2007
  • Mar 22, 2007
Oh you know. lol
But if its STARTING to mess up then there will be some rubber sticking out. When mine went bad it was hardly sticking out though. Maybe 1/4 an inch.
Stanger007
2,015
Baton Rouge, LA
Mar 22, 2007
  • Mar 22, 2007
You can look for rubber sticking out the back of it or see if it wobbles when the car is running - look at it from the side as if you were checking timing.
Or if your crank snout breaks off the balancer probably bad too.
Wes
HISSIN50
34
129
Mar 22, 2007
  • Mar 22, 2007
I'm surprised you haven't needed something decent by now - spray can make short work of cheaper balancers.
I would add that not any SFI is a good unit. There are several non-SFI units I'd rather run over some of the Chinese SFI units. Grady and I both have Pioneer SFI units - great bang for the buck IMHO. Others like Romac or PP units (get your mind out of the gutter ).
Good luck.
bimmertech
1,123
merriam, ks
Mar 22, 2007
  • Mar 22, 2007
Good luck.
1 more here for the pioneer sfi
think its like $180
Guero
2,148
Mar 23, 2007
  • Mar 23, 2007
damn well i better start saving for that
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Mar 23, 2007
  • Mar 23, 2007
I'm running a PP non sfi balancer and it has worked great. Now I'm only bolt on so keep that in mind. As soon as fund are there for H/I I will probably upgrade to a SFI one just to have it.
Stanger007
2,015
Baton Rouge, LA
Mar 23, 2007
#10
  • Mar 23, 2007
  • #10
I have the PP SFI - works great, no complaints. Have helped someone install the non-SFI PP unit as well - also looks to be a good piece and has held up.
Wes
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 23, 2007
#11
  • Mar 23, 2007
  • #11
One thing to keep in mind!
I've seen a few peeps go through 3 different OEM HB's before they went to something with more Quality.
I've seen many peeps go through 2 of them as well.
The stocker OEM is known to be not all that dependable.
Don't waste your money on another one!
Grady
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
1990 Mustang with no-start condition - Fixed and how-to
  • TTSaleen
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TTSaleen
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
