  • 1994 - 1995 Specific Tech
harmonic balancer
  • Thread starter Thread starter tstang21
  • Start date Start date Oct 4, 2008
T
tstang21
219
  • Oct 4, 2008
im planning on installing a harmonic balancer. its wobbling a tiny tiny bit. no rubber sticking out. im looking for a light weight HB. stock is 50z but what about a 28oz ? i have stock clutch and flywheel.
toyman
1,944
54
79
Vernon BC
Oct 4, 2008
  • Oct 4, 2008
I think you may be confused. The weight reference isn't about the weight of the balancer itself but rather the imbalance weight associated with the rotating mass of the crank as cylinders fire. The 50 oz is the needed imbalance weight for the HO 302. Use a 28 oz if you wish but expect early engine failure. Also, balancers are not all created equal.
Zero Signal
2,633
Tucson, AZ
Oct 4, 2008
  • Oct 4, 2008
I had a Romac balancer for awhile, the all-stainless (or aluminum, I can't remember) version. It was way lighter than the stock one with the same counterweight balance.
T
tstang21
219
  • Oct 5, 2008
oh ok. i didnt know about the difference in weight. so 50z it is.
HISSIN50
34
129
Oct 5, 2008
  • Oct 5, 2008
You've got it figured out.
You could kind of think of it like a wheel and tire. The wheel and tire weigh X amount, and you can do what you wish to pare down the weight of the wheel and tire. But you need to balance the wheel and tire, and you can't lessen the weight needed to attain zero imbalance (assuming you dont dismount tires and remount them to get a better initial balance). You just have to live with whatever weights the tire guy needs to use.
Pioneer/Powerbond makes nice SFI and street balancers as well, IMHO.
Good luck.
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
