Has anyone ever rebuilt their P/S Cylinder?
  • Thread starter Thread starter Pakrat
  • Start date Start date Feb 2, 2004
Pakrat
3,843
Currently: NH Originally: Rhode Island (and all po
Feb 2, 2004
  • Feb 2, 2004
I've been needing to replace a worn boot on the end of my pump and I have also just noticed some minor dripping going on. I see in many of the catalogs that they sell a cylinder seal kit for like $13 where as a new cylinder itself is like $120. I can't help but wonder if A) the seal kit will solve my leak and B) if it is simple enough to justify saving a hundred bucks not to mention the satisfaction of fixing it yourself. Seems I have little to loose, but I don't want to find out when it is too late that I need to also own $300 worth of specialty tools to do it.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 2, 2004
  • Feb 2, 2004
Pakster: "boot on the end of the pump"? Wanna tell me about that?
Rebuilding the power cylinder is relatively simple and effective provided it is not worn excessively. The instruction tell you how to do it OR simply: RTFM (see the Timeless Wisdoms as always) Be sure to clean and inspect the cylinder BEFORE you reseal it. Yes, I've done it many times.
DarkBuddha
2,215
Seattle & Tampa
Feb 2, 2004
  • Feb 2, 2004
I'm with SD... I've rebuilt mine twice since '88, and it sealed up well both times. It did eventually start leaking again, but that was a couple years later...
Rebuilding the unit doesn't require any specialty tools as far as I can remember, though it is kinda a hassle to do. Just follow the instructions, work in a clean environment, don't rush, and it should go ok.
Good luck.
67GTA-FB429
777
Tri-Cities, Wa
Feb 2, 2004
  • Feb 2, 2004
I am in the middle of rebuilding mine. Getting the inner seals out are a real pain in the a**. And I am still searching for silicon grease to coat everything in. Be prepared for a lot of fluid.
Swede958
712
Austin, TX
Feb 2, 2004
  • Feb 2, 2004
Rebuilt mine as well, and yes, the inner seals are a PITA to get out, but a nice pick and disregard for the integrity of the old part will suit you fine
THe Swede
67GTA-FB429
777
Tri-Cities, Wa
Feb 3, 2004
  • Feb 3, 2004
My wife "hooked me up" with a crochet hook....donated it to the cause. What a great woman.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Feb 3, 2004
  • Feb 3, 2004
The inner seal can sometimes be popped out.
remove the snap ring and outter seal, run the motor and turn the wheels from stop to stop. the pressure will sometimes push the seal out, but have a catch pan under the ram to collect the flow of fluid that will follow.
PB
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 3, 2004
  • Feb 3, 2004
As I stated before, a crochet hook works well. A LIGHT application of dielectric grease (as used in ignition work) is well suited for the task.
Pakrat
3,843
Feb 3, 2004
  • Feb 3, 2004
No not really, but since a picture is worth a thousand words and either my non precise technical terms are inadequate or you are choosing to bust my nuggets, how'z about I post a pic and you can look see for yourself. It's the item at the top right hand corner of the page
Thanks for the feedback guys, sounds like I have my first "the weather just got warmer" project all lined up now.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 3, 2004
#10
  • Feb 3, 2004
  • #10
Pak: I was funnin' you. You stated the the boot was on the pump (not the cylinder). See the top right pic in your illustrations. As a veteran poster here, you must realize that we ALL make gaffs and the occasional ribbing does us ALL good.
At least you know that someone actually READ and understood your post.
Pakrat
3,843
Feb 3, 2004
#11
  • Feb 3, 2004
  • #11
I figured you was funnin me SD, that is why I ended my reply with the same exact smiley as you. I actually said pump on purpose to refer to the boot at the pumping end of the cylinder, as opposed to the elbow dust boot on the end of the cylinder. Yeah, that's what I meant.
So tell me, what post did I miss where you stated before about the crochet hook? I tried a search first b4 posting and kind of came up empty.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 3, 2004
#12
  • Feb 3, 2004
  • #12
Trust me, the crochet hook reference is here but I can't find it either. It was within the last couple of days and not on this thread. I'm just not willing to spend that much effort to retrieve it. Of course, if you like to me to prove it, it can be done. It just seems so, well, pointless.
I don't knowingly make false assertations. I'mhere to have fun and that seems to be a scare commodity lately.
67GTA-FB429
777
Tri-Cities, Wa
Feb 3, 2004
#13
  • Feb 3, 2004
  • #13
Here is the reference S/D is talking about. Looks like you will need the boot kit and the seal kit (SU-91).
http://forums.stangnet.com/showthread.php?t=418972
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 3, 2004
#14
  • Feb 3, 2004
  • #14
67GTA: Thanks for saving what's left of my credibility!
Pakrat? See?
Pakrat
3,843
Feb 4, 2004
#15
  • Feb 4, 2004
  • #15
Credibility or proof was not the question nor would it ever be. I did the search before posing the question originally, as any good poster should do to avoid repetition like with those pesky engine swap threads. When I saw "as stated" but couldn't find the statement itself, I just wanted to make sure I hadn't missed any crucial tips or tricks or that my eyes weren't suddenly going bad on me since it implied the answer was right in front of me. I'm not sure how my question put you in such a testy defensive mood, but I have re-read it and see no hidden sarcasm or accusation what so ever. Just a simple question of what I might have missed. I'm here to have fun too, but it seems as scarce on your side of the fence as the other.
Thanks 67GTA! Looks like I missed little.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 4, 2004
#16
  • Feb 4, 2004
  • #16
OK, let's let it rest and then die. In retrospect, it seems to be a petty point to divide people "having fun." It is safe to say we both have lots of experience and savvy which can only be of benefit to the board.
Pakrat
3,843
Feb 4, 2004
#17
  • Feb 4, 2004
  • #17
Sure, I just wanted to make it clear that I was not questioning you, just asking you a question, that's all. I just didn't want any misunderstandings is since I prefer your presence as opposed to a lack there of.
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
JCBeaver's 1993 GT Coyote Swap "The Never-Ending Project"
  • JCBeaver
  • Aug 13, 2019
  • 8 9 10
34K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2020
JCBeaver
Progress Thread Project Fix This Thing Already!
  • Olivethefet
  • Aug 28, 2019
6K
1965 - 1973 Classic Mustangs -General/Talk- Mar 24, 2023
Olivethefet
Brakes 1979-1986 Fox Parking Brake Adjustment
  • LiquidStangs
  • Sep 22, 2019
10K
Fox 5.0 Mustang Tech Sep 23, 2019
LX Dave
L
For Sale 1968 Mustang Coupe - 5.0 with Holley Sniper EFI - Houston, Texas
  • Lookjam
  • Jul 19, 2018
  • Classic Mustangs For Sale
6K
Classic Mustangs For Sale Oct 23, 2018
Lookjam
L
