Hey vegas boy, you calling me a liar? Your info seems to be a little out of date. The kit is decent and the newer style heads PT#300-373 that come with all the new kits are actually very, very decent they just have cheap retainers, but they flow and make good power. AFR was asembling the newer heads for Holley, the old smaller valve heads were made and done by Brodix.The intake has also been redesigned a few times since the original kit and the lower ports are slightly smaller then the previous designs. The newer cam is better but still has a lot to be desired to max the combo, no issue with lack of low end grunt.
F-303 a race cam..lol All of the alphabet cams are OLD technology, much better off the shelf options are available. Unless you get a cam that is ground for use with a 1.7 rocker you actaully add additional stress to the valve train, it is better to use a larger cam with a 1.6 rocker. You need to check the pushrod length to make sure the geometry is correct, this was a big problem with the original Holley kits, most guys didn't check and just installed and ran, everything needs to be checked.
Yes, there may be better options out for more power, Holley or RPM2 intake, AFR 185 heads or TFS heads, CUSTOM CAM, 30# inj, 80mm Pro-M, 70-75mm TB, and even with a 9:1 motor you have a strong 11 sec recipe. IMO the Vic jr's are a little large for most street cars and they will require a aftermarket piston since they have a 2.05 valve. Either way you can go 11's.....
How fast do you want to go? Daily Driver or Weekend Warrior? Emissions or Non-Emissons? What's your budget?
