- Dec 3, 2004
- 39
- 1
- 0
Hey,
Have any of you mounted either of these mirrors? I originally wanted to run the r-model style (aluminum, I've heard them called Eleanor or R-model or Ray dots) but:
1. I would have to remove the door panel to adjust them (nut on the bottom)???!?!? I figured I could put a rivnut in the door, cut a hole in the bottom of the mirror (so i could get at the bolt head from inside the mirror) and use a bolt from inside the mirror, instead of the carraige bolt.
2. The base is about 1.5" dia and flat. Has anyone had any luck shaping the base to fit the contour of the door?
Has anyone had any problems fitting the second stlye (talbot Jr replicas)?
I now own both and need to choose. Yes I've tried searching and no luck, so any help is appreciated. I hope I post the pics right.
Dang, can't get the pictures below 78.1kb. what's up?
Please post pics of either of these is you have them mounted, especially the aluminum ones.
Thanks
Thanks
