- Dec 18, 2007
- 3
- 0
- 0
i have a 94 3.8. the other night on my way home it screeched for just a second than started running rough with the check engine light on. the light flashed a few times then stayed on steady. a code scan showed a misfire (#2 cyl.) and the left bank running rich. the next day i found a broken spark plug. i have since replaced all plugs, wires, coilpack, and one injector on cylinder #2. i have tested all plugs and wires and the ingnition is working fine. the problem is, there is so much gas dumping into the engine that it is pouring out of the muffler(like a faucet)!!!! i have unplugged both temp sensors with no luck. no trouble codes on the computer now. im ready to push it to the end of the driveway and let run till it catches fire. any help or suggestions would be greatly appreciated> thanks.
