  • SN95 4.6L Mustang Tech
Have a quick question, please help
  • Thread starter Thread starter stang676
  • Start date Start date Jun 16, 2005
stang676
82
corpus christi, tx
Jun 16, 2005
  • Jun 16, 2005
What rear gears come stock in a 2001 mustang gt with a 5-spd. At 70mph, i am turnung right at 2k rpm.
thanks in advance
stangman
2,690
10
69
in a 3 bed, 2 bath
Jun 16, 2005
  • Jun 16, 2005
stock gears are 3.27's
if you are unsure about the gearing here's what to do. get the back tires off the ground. make a mark on the inside of the tires, & also on the drive shaft. turn the driveshaft & for one full rotation of the driveshaft the tires should turn about 3 & 1/3 times if you have 3.27's (technically 3.27 times) or 3 & 3/4 time for 3.73's & so on & so forth
QU!CK
146
Charlotte, NC
Jun 16, 2005
  • Jun 16, 2005
thanks in advance
2k@70mph sounds right for stock gearing.
-J
trinity_gt
3,125
81
99
Canada
Jun 16, 2005
  • Jun 16, 2005
Backwards lad. Three point two seven turns of the driveshaft for each turn of the road wheels
If you want to be more accurate, turn the road wheels like 10 or twenty times and count the rotations of the driveshaft...ratio still equals # of driveshaft turns/number of wheel turns. Doing this helps pull out some of the uncertainty about fractional rotations of the driveshaft.
stangman
2,690
10
69
in a 3 bed, 2 bath
Jun 16, 2005
  • Jun 16, 2005
well you lla should wonk what i naem
0LASERGT1
Can I get a new CT? Something besides BANNED
Feb 25, 2003
129
Missouri
Jun 16, 2005
  • Jun 16, 2005
-J
quoted for truth and just so I can get one more on the post count
~TECHPOST~
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
