Have around $1500 for suspension parts...help!
Tasandmnm
I am not sure what to purchase to get the best bang for the buck. I have been looking at the Maximum Motorsports kits and also the stage 1 and 2 Steeda kits. Any recommendations? I am driving a 1993 Cobra that is pretty much stock under the hood (heads, cam, and more coming fairly soon). I want to improve my cornering and just stick to the road better in general :) Would one of the 2 kits above suit me best or should I do some mixing and matching? I am just a little on the clueless side when it comes to my suspension.
For about $1500, I would get the following:
1. Starter Box, 1990-93 Mustang SBX-2 includes: $1095
Bilstein shock/struts
MM CC plates
MM Road & Track springs
Isolators
2. Subframe connectors MMSF-1B $79.00
3. Adjustable Lower control arms MMRLCA-2 $380
and if your budget allows definatly get a Panhard bar at some point - it will make your car handle like it is on rails!
The Cobra already has the more desirable (softer) front sway bar so you are fine in the swaybar department for awhile. If you do all of the above your will be very impressed with the improvements of your car all around.
Thanks a lot for the advice! When I add MM's Panhard Bar to the equation my total gets to about $1900....ah well it will be worth it. Thanks again, especially for how detailed the info was with part numbers and everything.
