have question about front strut
eljefe
23
I got a 92 GT and im in the middle of replacing my front struts, and i notice that it has four steel washers where the strut bolts to the spindle, do i have to put those back?? or can i go without them?:shrug:
thanx
This is like 20 questions.
Are the washers between the spindle and struts or are they under the heads of the bolts and nuts?
I think what he is asking is that if the spacer is between the spindle and struts,you will needs it back in,even if it is a real tight fit ( I seen shops used a hammer and gently tap it back in). There should be 1 spacer on each side of the strut.
