Okay, so I was getting my car ready for the blower and decided to take off the pullies, t/a, C&L maf kit. Well after letting the computer reset itself, I drove the car around and found that it has developed a serious bucking issue at 2000rpms when just cruising at a constant rate of speed or when I slower down enough for the rpms to go below 2000rpms and the speed up again it bucks.
It almost feels like the engine is just plain shutting off and b/c it's at speed and the clutch is out it recovers and restarts itself. A few times when looking down at the tach, I saw the rpms drop when it bucked (I assume it would have read zero if the car didnt catch itself). Any ideas what is going on? I even went so far as to take off the C&L plenum and 70mm tb so the car is completely stock minus the LT's, mid-pipe, catback, and the only non-original part on the car now is a new OEM balancer bolt with washer in which I torqued down to factory specs. Any ideas of what the problem could be? Could there be a problem with the factory balancer being out of balance causing this issue? All the connections seem to be connected, there are no codes being thrown, and the car drives like normal at all other rpms, loads, and conditions. I'm stumped
