Having problem with heating after changing heater core
PeteyAce
346
I had a few threads but no luck, evers since my heater core went ive been having problems with my heat and temperature, whenever i turn the heat on my temperature goes up a considerable amount, also the fan switch for my heating console gets so hot that when it is on for long periods at a time (20mins maybe) it actaully starts to smoke and melted a bit by the back of the harness where it plugs into the switch. and other thing i noticed when i turn on the heat is that it sucks alot of juice out of my battery. Ive burped the system numerous times but nothing, those are my symptoms, this is my problem, any suggestions?
Sounds like your heater blower fan motor is frozen or binding, causing excessive current draw. You will need to replace the heater fan switch, connector, terminals, fan motor, and possibly the fan motor connector and terminals as well. When heater cores fail, they usually fill the heater case with water/coolant. It's not hard to se how the motor might get all rusted and refuse to function properly. :rolleyes:
