Having Problems separating my 302 and C4
  • Thread starter Thread starter monk302
  • Start date Start date May 1, 2005
monk302
742
New Jersey
May 1, 2005
  • May 1, 2005
Hey guys,
As the post said I am having some difficulty seperating the engine and transmission. So far I have done the following.
-removed five bolts that connect the bellhousing and engine
-removed 4 nuts that connect the flexplate and torque converter
-drained the torque converter
-separated the shifter from the trans
-disconnected the neutral safety and kickdown
-removed driveshaft
-drained tranny of fluid
-removed the c-4 trans crossmember
-removed the exhaust pipes from the headers
I have put the jack underneath the transmission pan and when I start to lower it I have been pushing the trans towards the rear of the car. It seems though that the two are still connected. Is that possible with the above listed? Are they usually difficult to remove? I am only using one jack and that is to support the transmission. I am not using a trolley jack. A
Anyone have any recommendations?
Thanks,
Mike
golf4283
1,253
Orland Park, Illinois
May 1, 2005
  • May 1, 2005
I would disconnect the starter. It probably is not the source of your problem but you don't wanna break any teeth yanking that sucker outta there. Otherwise maybe the tranny is just gunked on the back of the engine. Lots of years on the pair will probably have its toll on them getting kind of stuck together.
EDIT: definately take that starter out. it is probably what is causing the tranny to stay stuck together
geostang351
946
Danb., CT
May 1, 2005
  • May 1, 2005
Um, you said you removed 5 blots between the engine and bellhousing. There are 6 that hold the two together.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
May 1, 2005
  • May 1, 2005
Transmission cooling lines and hose to vaccuum modulator also need to be disconnected, (right side of tranny). Also the trans dipstick tube is bolted to the engine. Depending on year the trans kickdown cable. Isn't there six bolts in the bellhousing? Check all that and let us know,
Max Power
1,774
St Paul
May 1, 2005
  • May 1, 2005
Yup, unless you have an early 289, you should have six bolts holding the engine to the tranny.
monk302
742
New Jersey
May 1, 2005
  • May 1, 2005
Six bolts huh, I guess I will have to find that last one that is hanging on there.
-Starter is out
-Vacuum lines and cooling lines are removed (will I still be using the cooling lines?)
-dipstick is out
M
MitchGT
204
May 1, 2005
  • May 1, 2005
you won't need those cooling lines with the t-5. Since they go to the radiator, you can disconnect them there( or even get a radiator without tranny cooler). If your car isn't overheating, this probably isn't necessary, but sometimes every little bit helps.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 2, 2005
  • May 2, 2005
That was the first thing that came to mind. If the trans is still stubborn with all fasteners removed, it could have a tight fit on the alignment dowels. You may have to very carefully pry between the engine and bell and work them apart. I had to do that on my 5.0 the first time it was out. The second time the engine just slid right out.
69Rcode_Mach1
1,473
Salt Lake City, Utah
May 2, 2005
  • May 2, 2005
Just grab hold of the engine and wiggle it with all your might it will pop right off.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
N
Drivetrain AOD install - issue lining up TC studs to Flexplate holes
  • notch351w
  • Sep 28, 2024
Fox 5.0 Mustang Tech Oct 4, 2024
notch351w
N
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
