  • SN95 4.6L Mustang Tech
Having problems with Idle .. after putting in Accufab Plenum
  • Thread starter Thread starter madstyle1
  • Start date Start date Aug 1, 2004
madstyle1
21
  • Aug 1, 2004
Hey guys i just installed an accufab plenum with a 70mm TB on a 04 Mustang GT and when everything is put in place Also i put a spacer in between the plenum and manifold.. the car revs pretty high at neutral from 1500 RPM to 2000 RPM!! but when i shift to first it goes down back to normal!! Also sometimes it idles very high when i just turn the car on!! Now the TPS was set to 1 to .980 volts (according to the other mustang forums thats how it should be set) then i heard that the IAC has to be clean.. but the car is new so it should be clean to begin with.. Im also hearing that it takes a day or two for the computer to learn new items on the car? is that true?? Can anyone help me here!! its very frustrating!!
madmatt
Ellis Juan sympathizer
465
Lexington, SC
Aug 1, 2004
  • Aug 1, 2004
take the spacer off. Ive heard that if you use a spacer and the plenum, it will cause an idle issue. Also check for vacuum leaks, someone else on here experienced this problem and it was a leak
slangstang
  • Aug 1, 2004
Vacuum leak
Installed the 75mm Accufab T/B and Plenum on my 03 GT about 2 weeks ago. Initially when sitting in neutral it would hang at about 1250 rpm after having blipped the throttle then settle down after about 5 secs. or so to a normal idle. Would also do this when coming to a stop. Read some good info here about vacuum lines so sealed all the line with high temp RTV and made sure I went through the proper procedure for resetting the computer. Everything is good now. Look in the section in your owners manual about changing the battery. It has the computer reset procedure and be sure you leave the negative lead from your battery off for at leat 45min. before doing it. When it resets you will see your guage needles go fully to the right, then back to normal. If you don't see this you didn't leave the battery unhooked for long enough. After you see this, follow the procedure in the manual.
madstyle1
21
  • Aug 1, 2004
I think i found out the problem... i think the reason why its doing this is because i dont have a gasket on the spacer ... between the plenum and the manifold... hopefull thats the problem and it can be solved very easily....
twogts4us
4,188
12
79
Dunedin, FL
Aug 1, 2004
  • Aug 1, 2004
Get rid of the plenum spacer!!!!
When you are removing it, disconnect the neg bat cable. When you're done, reconnect. Turn the key on and watch for all the gauges to peg then fall back down to zero. Then start the car. Mine still took a week of driving to completely settle down, but it wasn't idling at 1500 - 2000! (That's being caused by that spacer!) It was more like 1000 - 1200 for a couple secs, but now its more or less back to normal.
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 1, 2004
  • Aug 1, 2004
the spacer is the problem, take it off. the plenum has a built in spacer, so there is no need for another
stang9300
111
North Carolina
Aug 1, 2004
  • Aug 1, 2004
I agree with canning the spacer. Also it may take the car a little while to start idling normal again. Give it some time.
StangLou
1,264
Holly Springs, NC
Aug 2, 2004
  • Aug 2, 2004
No spacer needed man. After my install the car would hang at around 1300rpm when coming to a stop or when I would blip the throttle. It took around a week or so but it stopped doing it altogether. Just reset your eec or give it some time. It will drop on its own
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
