Having problems with my car, yet again!
  • Thread starter Thread starter Must-Be-A-Stang
  • Start date Start date Dec 13, 2004
Must-Be-A-Stang
66
Enid Oklahoma
Dec 13, 2004
  • Dec 13, 2004
Ok, first off, Id like to say thanks to those of you who have helped me through my 4:10 install. I got the crush bearing crushed. There was allot of slack, and the gears whined when I let off the gas... after a car lift and a big ass impact there is not much play and there is no more whine. So thinking I was off the hook, I ran into a new problem.
I decided to go out and ''get er done'' and see what she had in her.. I rip through the gears and im pumped. I hit 4th and Im doing probbly (no speedo gear) 70 mph, I go and hit 5th and I was shocked to feel a violent vibration. I was like ''holy hell!!''. I brought it down and easly went through the gears till about 55 60 mph and hit 5th and there it was again. Seems to be only in 5th and kinda goes to 4th if I down shift. At one speed in 5th I thought my hand was gonna come off the shifter. Is this the drive shaft?? Do I need to buy a new one that is balenced? Can someone explain what makes this happen? I heard a few complaints about vibration but this sucks.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 13, 2004
  • Dec 13, 2004
You put in gears, that driveshaft is spinning much faster, so if it's out of balance, even a little, your really going to feel it. The aluminum is nice, but really expensive, just put new U joints in the stocker and get it balanced. Yes, when mine shook, it was a little over 70mph, shook pretty bad.
PNY PWR
522
Wichita, KS
Dec 14, 2004
  • Dec 14, 2004
I have an aluminum driveshaft, FRPP 3.73's, and a T5. I get some vibration in 5th gear too. I'm convinced it's in the tranny. Everything else is good or new.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
L
Engine 97 mustang gt manual weird idol when off the throttle and coasting in 3rd, 4th, or 5th
  • Lanezs
  • Jun 9, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
