ok so heres the story i bolted a paxton novi 2000 blower onto my car, and about a month ago i brought it down to J&M motorsports in connecticut sor dyno tuning, on the first power run it made 420 HP and 398 ft/lbs of torque and blew a head gasket in the process.
i tore the car down and found out that my block was missing a couple of o-rings and thats why it blew the gasket. i re o-ringed the block and put some stainless steel rings in the grooves(had copper before)and put everything back together.
i had the car towed down to J&M last thursday to have it retuned and they went through and got the base tune done and made one power run and this time it made 480 HP and 440 ft/lbs. of torque. the car blew a gasket on the opposite side of the motor this time and J&M told me this time its wasnt ass violent as the last time and he said it only smokes when the motor is warm.
anyone have any suggestions on what i should do to fix this problem, i think its the block that is not flat and this is why i am having so much trouble. if it help the blower is making around 9-10 lbs of boost and the timing is set a 10* BTDC and in the computer it is set a 22*
