on my way to work my passenger side window and turn signals stopped working but my hazards still work, no idea why, checked fuzes. i read that there is a flasher box or something under the dash but dont know where, any ideas?? thanks
Joel
Joel
The first thing I would check for is the hardshell connector on the multifunction switch. Remove the steering column shroud and unscrew the multifunction switch. Gently pull on each wire where it goes into the connector ON the multifunction switch. If any of the wires feel loose or actually come out of the connector, you just need to replace the connector. It is a common problem.
The connector can be had at any Ford dealership, just tell them you need a hardshell connector for the multifunction switch. Then unpin each wire one at a time and plug them into the new connector in the same location.
so where exactly above the fuse panel is the flasher of the turn signals, i'll check that and the mulitfunction switch/hardshell tomorrow when its light out. is the hardshell a dealership only item? or can i get it at like kragen or someplace like that?
