The things that were done to the car recently were: trickflow hci kit(so it has tw heads and stage 1 cam), 75mm pro m maf, 24lbs injectors(yes they match the maf), accufab 75mm fox style throttle body(elbow was deleted), egr and smog were deleted, asp underdrive pullies, mac longtube headers and pro chamber midpipe, new o2 sensors and 180 degree thermostat.
The transmission was swap for a tko unit along with new clutch, lightweight flywheel and aluminum driveshaft.
I replaced the fuel pump to a 255lph unit along with a fuel filter last year and balancer too. The wires were replaced a long with cap and rotor last year. The mechanic also changed the plugs.
The mechanic set the timing at 12 degrees and fp at 38 and made sure everythings else was working right with no vacuum leaks and said that the idle is the pcm not liking the cam. When I was driving it didn't seem to hesitate or buck when it was on load, it's just when it's idling that it fluctuates up and down and has a hanging idle(when the clutch is push the rpms stay where they were at for a couple seconds then they come down and wants to die).
I do not have any sort tuning device on the car at all. That's why I was hoping someone could help me out with just getting the car to idle right. Thanks.
