  • 1994 - 1995 Specific Tech
HCI Install Question.
  • Thread starter Thread starter GRGT1994
  • Start date Start date Jul 5, 2005
GRGT1994
1,034
  • Jul 5, 2005
I have my motor partially stripped down now. Next off are the accessories, headers, then the heads (intake is off).
So I would like any suggestions you might have on dealing with the accessories. Like, is there any way to get around pulling the power steering pulley? Can I pull the power steering and AC compressor aside as one unit by just removing them at the bracket? Any other suggestions for dealing with this side of the engine? And what about the alternator, balancer, water pump? I am pretty sure all that needs to come of too.
Thanks for the help. (I love my PB Blaster bottle right now!!)
94-302-vert
1,947
NE CT
Jul 5, 2005
  • Jul 5, 2005
I haven't done it myslef but when my Bid tore down his 94 for H/C/I a couple years back he had to do it all. I know because I was there to help put it all back together...
I think he had rented the PS pulley puller at the local parts store...
bayellowstang
462
Carlisle, PA
Jul 5, 2005
  • Jul 5, 2005
there is no way around taking off the PS pulley. I tried all possible ways.
There is a bolt that holds the bracket to the head behind the PS pump. The bolts that hold the PS pump on the bracket are too long and hit the pulley before they come out.
Faster and eaiser to get the puller and be done.
CManT1914
3,172
Killeen, Texas
Jul 5, 2005
  • Jul 5, 2005
The power steering and a/c can stay on the actual bracket, and the bracket can come off and be swung out of the way. But you must take the power steering pulley off. The balancer of course has to come off too. Sears (and other parts stores) sells a balancer puller for $20. I ended up buying it, because I have no doubt I will be switching out cams in the future again.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 5, 2005
  • Jul 5, 2005
The puller for the ps & hb can be borrowed from your local auto parts store. A lot of them have you put up a deposit and when you return the tool, your get your full deposit back.
Each application takes a different puller, btw.
If you want to buy the pullers they are not expensive if you shop around.
I've seen some say they got the ps off without removing the pulley but you have to work at it a good bit. I've not tried it but I can see how you could do it. If you got the correct puller, its really no big deal and it would seem to me that removing the pulley would be the least amount of work.
Later
Grady
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
D
6G alternator pigtail wiring help needed
  • Dogman_1969
  • Aug 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 11, 2025
Dogman_1969
D
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
