head bolt questions
  • Thread starter Thread starter jaymac
  • Start date Start date Jul 12, 2005
jaymac
995
Northern Mass
Jul 12, 2005
  • Jul 12, 2005
Finally got my ARPS's today
Final Q's:
ARP included their own Moly lube for use on the threads and recommends thread sealer on the short bolts. Now, I have Teflon tape. Will the tape affect/throw off the torque readings?
How many times around should I wrap the tape?
Do I need to wrap just the threads or the whole bolt?
Do I need to use the washers supplied w/ the bolts?
I think that's all for now....
Thanks!
sweet88gt
334
Venice FL
Jul 12, 2005
  • Jul 12, 2005
Dont use the tape that wont last long in the water jacket and may come unwrapped and clog the somewhere in the block. Use Permatex gasket maker on the short bolts. It comes in a small can usually and is a black sticky liquid.
As far as the washers I would use them if they came with your application. The would keep the bolt from digging into the head. Torque the heads to the specs and call it done.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 12, 2005
  • Jul 12, 2005
Use arp or permatex thread sealent on the lower bolts and arp moly lube on the uppers. Don't be afraid to use a lot on the lowers. Everytime i've bought arp head bolts it never came with arp lube.
Scorcher2005
883
South Carolina
Jul 12, 2005
  • Jul 12, 2005
if i hadnt read this i wouldnt have ended up using anything on the head bolts. can black rtv be used instead of the permatex?
jaymac
995
Northern Mass
Jul 12, 2005
  • Jul 12, 2005
Wow, that sucks. I actually got them through Autozone, and they were listed as an Edelbrock part, but they came today and they're ARP's, w/ the ARP sticker, ARP instructions, ARP moly lube, the whole 9.
Weird.
So that's an ix-nay on the Eflon Tape-Tay?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 12, 2005
  • Jul 12, 2005
All the bolts get antiseize under the bolt heads, and everything but the short head bolts get it on the threads. You need Teflon pipe dope or ARP sealant to coat the threads of the short head bolts. The short bolts go into the water jacket and will seep coolant if you don't use the sealant.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 12, 2005
  • Jul 12, 2005
Yep, put antiseize on the washers (use them) so it doesn't hurt the torquing against the head or bottom of the bolt that mates against the washer.
Use thread sealer (not the tape) and cover the threads with it. I used ARP...very nice
Use some oil or moly lube on the top bolts.
Scorcher2005
883
South Carolina
Jul 13, 2005
  • Jul 13, 2005
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
