Head flow = ? HP
pb_paulie_b
894
Chaptico, Maryland
Hello peeps. I have a question concerning the horsepower potential of my heads. Here is the head flow data...
Intake Valve Test @ 28” of Water
.100 .200 .300 .400 .500 .600 .700
76 149 214 260 289 305 309
Exhaust Valve Test @ 28” of Water
58 120 157 182 189 194 199
How much horsepower will they make NA?
The victor Jr's do not flow as well as urs. 268/189 @ .500 lift, 291/195@ .600 lift out of the box.
http://users.erols.com/srweiss/tablehdc.htm
The only thing I see as a downside is the exhaust flow @ .500 lift, s/b 210 or more. My TFS Hi-ports flow 290/210 @ .500 lift and most others with 300 cfm flow in the 210 range.
On a NA 11:1 comp street engine with a .585 lift, 232/240 dur cam, 110LC, port matched RPM ll intake, LT's and those heads u could put down close to 375rwhp on a 306, and on a 347 with a Victor or TFS-R intake 400rwhp.
Just remember don't get too caught up in flow numbers....it's not what they flow but how they flow and move the air.
From what I have seen the Vic Jr's do not flow the advertised numbers out of the box, the tend to be low. Every bench is different, along with the tester, bore size, pipe or no pipe, clay at the entry etc....
i have heard this about the vic jrs ALOT
The formula for horsepower potential concerning headflow is .257 x #of cylinders x cfm. The only thing not accounted for is cubic inches. The number you'll get is what the heads can support.
You may not be able to reach the maximum horsepower they can support with only 302/306 cubic inches N/A.
Example: Factory E7 heads can support around 340hp. I'm pretty sure it's very difficult if even possible with only 302 cubic inches. Cubic inches don't affect the horsepower the heads can support, but whether or not you can reach the hp potential naturally aspirated.
