  • 1994 - 1995 Specific Tech
Head Gasket Install
  • Thread starter Thread starter Danman765432
  • Start date Start date Apr 23, 2008
D
Danman765432
471
Nutley, NJ
Apr 23, 2008
  • Apr 23, 2008
1. I was just wondering if you install the head gaskets dry or with rtv since I am going to be doing it in about a half hour or so?. Im just putting the water pump back on now.
2. Also do the water pump bolts need a thread sealer or anything like that?
3. Also the stud bolt that goes into the water pump goes in which hole?
4. Also what do you put on the cylinder head bolts, antisieze, lock tite or thread sealer?
Ok I think that is it...more questions than I thought I would have been posting in here.
Thanks,
-Dan
Bosko5.0
1,067
longwood, FL
Apr 23, 2008
  • Apr 23, 2008
1 Dodn't use rtv
2 yes use thread sealer since they go into the coolant.
3 ???
4 use loctite
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Apr 23, 2008
  • Apr 23, 2008
I NEVER use loctite on headbolts.
Put thread sealer on the lower head bolts.
No thread sealer needed on the water pump bolts.
Install the gasket dry.
k00ksta
158
Chicago
Apr 23, 2008
  • Apr 23, 2008
1) Ya I always installed the gasket dry. You could if anything take your finger and put a little motor oil on it but I dont think you need to do that.
2) water pump bolts I believe you dont need to use anything on the bolts but of course around the pump its a good idea to use Black RTV if im not mistaken.
3) not sure off the top of my head.
4) I never use loc tight or rtv sealer on Head bolts! ever! its not fun when you have to remove them due to another blown head gasket or what not. what I do is pickup ARP Head bolts (hopefully thats what your using) dip the threads in motor oil! yes Motor oil! for a little bit of lubrication and it will help you torque them down. Also be sure to torque them down!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 23, 2008
  • Apr 23, 2008
You have to use some sort of sealant on the head bolts that pass into water jackets. I used blue Loctite on my studs. You have to use quite a bit of it though, so that you can guarantee there's enough to seal the threads.
blksn955.o
3,263
st.louis mo 314
Apr 23, 2008
  • Apr 23, 2008
I acually did have a leak at a water pump bolt once. Ever since I have put a thread sealer/dab of RTV on the threads.
I used a dab of RTV on the lower head bolts since they go into a water passage. Thread sealer would be better as you will get less drag and a better trq. on those bolts.
Adam95GT
2,564
Burlington, NJ
Apr 23, 2008
  • Apr 23, 2008
do you have to put rtv on the head bolts... i think i just put them in dry or with a little oil ...
D
Danman765432
471
Nutley, NJ
Apr 24, 2008
  • Apr 24, 2008
ok thanks a lot guys...I finished the waterpump and all that stuff and have the heads mounted but not torqued down...Ill do that on friday...ID didnt get a lot done since I had to try and fix my brothers beater that I am using now since the driver side door wont open.
Methodical
1,192
11
59
Clinton, MD
Apr 24, 2008
  • Apr 24, 2008
What kind of head gasket are you using?
Be sure to do at least 3 torque cycles.
D
Danman765432
471
Nutley, NJ
Apr 24, 2008
#10
  • Apr 24, 2008
  • #10
The one that comes with the fel pro head gasket set
Also was I only suppose to but rtv on one side of the timing cover gasket or both?
Methodical
1,192
11
59
Clinton, MD
Apr 24, 2008
#11
  • Apr 24, 2008
  • #11
Danman765432 said:
The one that comes with the fel pro head gasket set...
Ok. I asked because if you were using the MLS I wouldn't suggest some dressing on the gasket.
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
