Head Gasket?
BBrinks
519
45
Woodridge, IL
I was driving the other day and the car sputtered for a second and then ran great. It was fine for a couple of days and then started sputtering and missing pretty badly. I got it home and let cool down for a bit, and then took it around the block. About 1/4 mile down the road, it starts sputtering really badly and was blowing white smoke through the driver's tailpipe.
I started taking it apart tonight and pulled the front drivers spark plug (no. 1?, can't remember) and it was wet. The rest were fine. Would this be a blown HG or a lower intake manifold leak? The oil was clean and the reservoir wasn't boiling over or anything. Also, I haven't done a HG before, should I just replace both while I'm at it?
did you start to see the white smoke during regular driving conditions or were there some WOT runs in there resulting in the white smoke?
ususally you dont just blow a head gasket during normal driving conditions
what is your timing set at and what gas do you run?
are you actually losing coolant or oil? is there coolant in your oil or oil in your coolant?
something to think about....maybe your spark plug went bad or your plug wire... i think if you had a bad plug or wire or something, that your spark plug would be wet with fuel and you would probably get smoke out of your tail pipes from the unburnt fuel burning up in your exhaust....
i'd look into that first and do a compression test on your cylinders
BTW that is cylinder #5 :D
I run 87 octane and the timing's set to the stock 10 deg. I was just driving normally when it started blowing white smoke out. It wasn't just a little bit, though, it was pouring out pretty good. I haven't run a compression test yet, so i'll try that and see what comes up.
Well I took out the lower intake and here's what I found:
And here's the intake:
I thought it might be the head gasket, but now I'm wondering if the manifold gasket was causing it. The only spark plug that was wet was the #5 one, and that's about the only one where the intake manifold was chewed up like this.
I do the oil changes myself and it's never had any indication of coolant in the oil. Even now there's no coolant in there. I only drove it around the block when it started smoking so hopefully it wasn't long enough to do anything. The gasket's pretty nasty though, so I don't know if just an installation problem or something else. I bought the car with the intake already installed. Hopefully this cures it.
Does anyone know where to order the upper-to-lower intake gasket from? I looked on trick flow's site but only saw the lower kits.
