Head Gasket?
Head Gasket:
Block:
See the pattern difference? See how it's going to block off one set of cooling passages at the end of the block?
The "FRONT" always goes to the front, no matter what side of the engine it goes on. The water passages in the lower intake manifold take care of routing the water in the correct fashion.
Even if it means flipping the gasket over?
YES.
Fel-Pro marked them that way to insure that the gaskets get installed correctly. There is no difference between the RH gasket and the LH gasket, there is only one type of gasket.
There is no "This side up" either, only "Front" that always goes to the front.
Pulled the head and flipped the gasket real quick. Here's how she sits as of now:
I managed to lose one of my intake bolts so I'll be ordering another one from ARP tomorrow morning and then I can go ahead and finish everything up.
