head light problem on '95 mustang
  • Thread starter Thread starter RKLRacing
  • Start date Start date Nov 1, 2005
R
RKLRacing
Kent, Wa
Nov 1, 2005
  • Nov 1, 2005
I recently purchaced a '95 mustang GT with a few problems. I have fixed most of the problems but one. This car seems to have day time running lights. At night with the headlights on, they flicker between high and low intensity. The same thing happens with hight beams on. I pulled the gauge cover off to look at the head light switch. The factory harness is chared, melted and cracked. I would like to replace the factory switch and wiring harness connector to see if this will fix the problem. Is it best to go the the ford dealer for these parts? Do they still sell them? RKLRacing
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Nov 1, 2005
  • Nov 1, 2005
The melting wire cluster was a major problem for our vehicles and also explorers for that time. You CAN go to a junkyard and grab these peices out of another V8 or even a V6 model mustang, that's what I ended up doing. My taillights just ended up not working, i checked the wire cluster, exact same problem. Don't go to Ford, you'll pay too much for too little.
Hope that helps
R
RKLRacing
Kent, Wa
Nov 1, 2005
  • Nov 1, 2005
Thanks
That is probably best. I will check locally for junk yard parts. I might also check with some FFR cobra parts supplier to see if they have these parts cheap.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
